What Settings to Tone-Map HDR to SDR for Livestreaming?
In settings/advanced if you select NV12 and Rec 709 (or Rec 601) you can transmit or capture a source captured in PO10 and REC 2100 (HDR)
i'm on version 32.1.2; this doesn't cause any errors but HDR streaming to youtube HLS does not receive HDR (PO10 and REC 2100). It receives the color format of the canvas even though the capture source (gaming capture) specifies the HDR color formats
Haha, sorry, that's a trick for streaming an HDR source using the HDR source captured at the highest quality, but in SDR—not in HDR. In other words, the capture device doesn't use NV12 but rather P010 ETC . And I think the result looks better than capturing directly in NV12. I used it in the 4K beta on Twitch.
