OBS Studio Mac Desktop-Audio using BlackHole
asher_the_thrasher submitted a new resource:
Mac Desktop-Audio using BlackHole - An updated, easy way to set up mac audio on all macs running macOS Mavericks (10.9) to macOS Big Sur
1. Download here (note, you will have to put in your email but that is to get the download link)
2. Once you get an email from BlackHole audio, open the link. It will take you to the download page. Download the 16 ch version and install.
If, when you open the download, you get a message about not being able to open 3rd party apps, go to the...
Hi. What else do I have to change to record desktop audio? Unfortunately it seems the mixer doesn't detect the sound.
i went thru setup Blackhole and multi-output device and got it working, some months ago. and it was working a few days ago, but i must have clicked something by mistake and now cannot get audio out to my bluetooth speaker, nor my internal speakers. i do see the audio meter bouncing when recording in obs, and resulting recorded clip has audio, but still cannot hear it myself as i'm recording
using old Quasar VHS playback deck, DIGITNOW USB 2.0 Audio/Video Converter MacbookPro 2014, OS = HighSierra 10.13.6, OBS 27.2.4 (64bit) Blackhole 2ch,
any suggestions?
any suggestions?
FOUND IT!!! in the audio advanced tab, monitor needed to be enabled
I did these exact instructions. OBS is picking up audio from a YouTube played, so it is picking up desktop audio. But I am trying to pick up audio from Tidal Cycles and it is not picking that audio up. I can hear that audio in my headphones and Mac speakers though. I know this is not an OBS issue, but maybe someone else here has run into this.
hello . i have blackhole. on obs on both my imac and macbook pro . on recording. on macbook pro is picking up nice and smooth the youtube music . on imac .. same settings ... the. sound of music sounds like an old broken radio .. interrupted ..volume loosing ... went thru everything over and over. again ...same things happening .. any idea what. could be ?
Hello
I use OBS to record desktop audio from my macbook pro. I use it to capture audio from FL Studio and I want to do the same with Pro Tools.
I am an audio engineer, I would like to record my screen an audio.
I make my Multi-Output device and set my desktop audio to that as well as the playback from my DAW (FL Studio or Pro Tools)
I can capture the playback audio, but when it's time to record, my inputs (mic inputs to my interface)m aren't available.
If the DAW is not set to this multi-output device, I get no audio captured from the DAW.
How can I record/stream and record in my DAW?
